Rectangular Form Factor / 16 GB capacity / Announced September 12th, 2012
111вопросов Показать все
Broken battery flex cable
how do you remove the battery from the main logic board.
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Hello!
The battery is soldered to the logic board, so to remove it you need to heat up the solder pads using a soldering iron. Apply heat to the shiny solder pads not the ribbon cable. I recommend buying some solder wick for the removal, it collects all the solder so when it cools and sets again (Seconds after heat is removed) Then it cannot adhere probably as there is no connection or a minimal one.
It isn't needed but if you are with little experience then doing this will remove a lot of the frustration involved when the different solder pads cool whilst you're applying heat to the others.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
waajid muhammad будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 477
