Is it possible to adapt this tuner to work with any amplifier?
Hi Everyone,
I have the above tuner, but not the amplifier which is designed to connect via a ribbon connector to power the tuner and carry the audio signal. Is it possible to adapt the tuner (perhaps with a mains adaptor supplying the correct voltage), so that the device can be connected to a "normal" amplifier with conventional audio leads, etc.?
Unfortunately, there does not seem to be any labels showing the voltage etc. that the device works on.
I also have the cassette tape deck and graphic equaliser from the system, so if there is a solution to this problem, it will probably work for these devices also,
Many thanks, Peter.
Это хороший вопрос?
