The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
211вопросов Показать все
Glass touches LCD Screen
I dropped my galaxy note 2 and the screen cracked. I replaced it with another one I purchased online. Everything works well except that a part of the glass touches the LCD creating a bubble looking effect.
I use 3M 2mm double side tape for the glass.
Did I curve my LCD screen or anything?
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
There is meant to be a rubberised seal between the glass and the digitizer, I'm guessing when you removed the glass that came off with it.
The addition of the seal also acts as a spacer between the glass and the digitizer so that the problem you are having does not appear.
Был ли этот ответ полезен?
Оценка 0
Hi ,
I also dropped my mobile. Screen cracked.
I want to replace it.
Can you please tell me cost of this.
Samsung Galaxy Note 2 :-
Screen Broken and Stell case also i want to change
Please send information to my mail id:
greenapples2010@gmail.com
Thanks
King
Оценка 0
Добавьте свой ответ
Kevin будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 1,118
