2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
265вопросов Показать все
Вопрос закрыт
Hidden Wi-Fi ac support
I think the MacBook Pro Retina Early 2013 secretly supports the Wi-Fi ac:
With the application WiFi Explorer, we see that it recognizes the ac network of my AirPort Time Capsule, plus, it's able to see the signal strength (which is different from the a/b/g/n network because of the beamforming).
More: The network in bold is the one currently used...
I think maybe Apple will release a "ac activator, like they did for some Intel Macs.
But first, we need to be sure that it's not just the app that recognizes the network.
So I need some testers to see if with (any another Mac and an ac AirPort Extreme) you can see the ac network and the signal strengh. The app that I used is named WiFi Explorer and is available here.
Note: My MacBook Pro Retina 15" is running on OS X Mavericks.
Это хороший вопрос?
Оценка 0
Добавить комментарий
4 Ответов
Выбранное решение
Hi Dean,
802.11ac is backward compatible with 802.11n adapters, so your MBPr is able to detect 802.11ac networks, display their information, but can only connect to it using 802.11n. There's no such a thing as hidden 802.11ac support in your MBPr.
Sorry!
Regards,
The dev behind WiFi Explorer
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Thanks for the explanation! :)
из
Наиболее полезный ответ
Sorry Dean I think your seeing ghosts ;-}
The app is just showing you the header label from the other systems hello. I really don't think your MBPr has hidden 802.11ac support.
Another way to look at this is if the AirPort card your system has was the exact same as what the newer Air systems have (which from the IFIXIT teardown it doesn't).
Оценка 2
This is more "posing a question" to stimulate further discussion, than an answer, but...
Apple occasionally (through firmware and OS updates) update changes that enable previous or current generations of product to increase transit rate capability of existing airport cards (ie, instead of a 802.11n with a transit rate of 300, retina's with the "n" class card can use up to 450. Originally, the A1369/A1370 (2010/2011) macbook air's model(s) were spec'd at a transit rate of 150 I believe, but are now capable of 300 due to updates incorporate with the OS and firmware. But that capability - as I understand it - is on 5GHz networks (I think). Can't be sure on that one. It doesn't change the 802.11a/b/g/n/ac .... but it is pushing the card in its capabilities.
Please... anyone feel free to jump in on the comment and correct any misinformation. I don't mind :)
Оценка 0
I think there is no any such option for hidden wifi ac support
Оценка -1
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 2,062
