The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
523вопросов Показать все
Replace LCD flex without separating LCD and digitizer?
I found a tear in the flex cable for the LCD while doing a repair on the i545 verizon galaxy s4. Before I start taking the front assembly apart is there anyway to remove the cable without having to seperate the glass and digitizer from each other and the case?
Это хороший вопрос?
Оценка -1
Добавить комментарий
3 Ответов
Выбранное решение
short answer is, You broke your flex to the LCD and the flex is not repairable well at least for the average joe. Its best to buy a new LCD display.
Был ли этот ответ полезен?
Оценка 0
How would you replace the flex cable? I'm not an average joe
Оценка 0
You can't. Once that cable is broken, it's broken. Move on and get a new lcd.
Оценка 0
Добавьте свой ответ
Charles Warren будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 1,947
