The location of antennas in ipad4
where is the location of wifi and cellular antenna in ipad ?
Это хороший вопрос?
Это хороший вопрос?
The wifi antenna is along the bottom frame toward the right. Sits between Digitizer and frame. The 4G antenna and GPS are at the top, also slightly adhered to the digitizer. If you look on the back, you'll notice black bars at the top of the ipad, that's where they are housed.
Был ли этот ответ полезен?
Is it the same as the ipad 3 3g version ?
Bottom antenna is for wifi/BT
There are 3 top antennas, 1 GPS and 2 cellular. iPad 3 and 4 should be very similar, if not identical.
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 1,339
1 Комментарий
i also want to know this !
could somebody help ?
из Timmy
