Apple's line of iBook laptops was intended for the consumer and educational markets. The iBook line comprises of the iBook G3 Clamshell, G3 12", G3 14", G4 12", and G4 14".
832вопросов Показать все
Why the LCD don't turn on.
If I push the power on the computer will turn on. I know it because of the sound that it creates whenever I turn it on. I knew the laptop is working because there's a light on the cap lock key if I press it and the dvd player will open if I push the eject button.
I've been using this laptap everyday. Maybe it was shaken during my travel home. Maybe a part connection was lossen. When I turn it on the lvd is black out.
Do you think I need to replace the lcd screen?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Hook up to an external monitor to test the GPU. To check the hard drive hook up via a firewire cable to another Mac and boot using the "T" key. Then run Disk Utilities from the second Mac.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
+ Ralph
из
Добавьте свой ответ
eddie будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 508
