The MacBook family was first introduced in May 2006 and replaced the iBook as Apple's consumer laptop.
4127 Questions Показать все
Various Laptops with Power Issues
I have, over the past few years, have what seems to be the same issue with 4 different laptops.
About 3 years ago I had a Compaq Q60 laptop, one day I plugged the charger in and noticed there were no lights and it wasn't charging - the laptop continued to work till the battery went flat. After googling my issue it seemed like this was the norm for these laptops so I didn't bother fixing it. I decided to buy a new MacBook Pro 13". 14 months later I had the exact same thing happen as did with the Compaq. Once again after googling, I replaced the DC jack (see my first question in regards to this issue) but this didn't fix the issue. After months without a computer, a friend lent me his newish HP laptop, after a couple of months the SAME thing happened, I thought it may be the charger so I did nothing. About a month ago I then brought a used Macbook 13" (not a MacBook Pro) and placed my Pro harddrive into it and had a perfectly working mac, until last night SAME thing. Although I did notice that when I plugged the charger in the green light momentarily came on then went off and nothing since - is this all just a coincidence or what?
One thing was that I was using the same power outlet each time the laptops "died" but I have other electrical appliances (TV, DVD etc) using it too and they're fine. I'm at a total loss
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 0
Добавить комментарий
Комплект инструментов для замены батареи Macbook
Доступно с $69.99
Buy Now
Доступно с $69.99
Buy Now
1 Ответ
Выбранное решение
Seems to me you're hard on laptops. (4 in 36 mos - minus some downtime with no laptop at all).
Following the charging/discharging/use guides of the manufacturers is essential to battery life Every battery has a finite life. This life can be drastically shortened by misuse. or, extended with care.
I think I would invest in a UPS power supply/battery backup to ensure a normal steady current to the laptop at all times (brown outs e.g. current/voltage drops, are worse than power surges for computer hardware). Other hardware is more robust/forgiving - might even have some onboard protection... (for that mater you may have 4 laptops with tripped fuses on logic boards or inside batteries -todays batteries do have onboard logic/charging circuits-).
It might be a good idea to have your home wiring checked... especially that outlet
If this Answer is helpful please remember to return and mark it Accepted.
Был ли этот ответ полезен?
по рейтингу 1
Добавьте свой ответ
Lisa будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 72
