RAM Memory Module holder malfunction need to replace?
I want to know if its possible to replace a RAM memory module holder of my MacBook (white).
Because it surely is broken as it cannot see the memory any more. When i turn on my MacBook its just only sounds beep beep ... so on.
Before I took out the memory then put back again which fixed it. As times has gone by doing that frequently it has now stop working anymore as I broke the small plastic latch that holds the ram module in the holder. Is it replaceable?
Thanks
Это хороший вопрос?
2 Комментариев
thanks for the response. my laptop is 2009 model. http://km.support.apple.com/library/APPL... this one is he problem. its core 2. have any idea how much does it cost if i bring it into service center of mac? coz this kind of repair is so difficult for me.
из brian
A logic board replacement will probably cost you around $550-600 at most service shops. The board is typically the most expensive component inside the Mac, ranging from $400-500 on average. You can usually expect to add about $100 on top of that for the shop's labor.
из LikeARabbit
