WHEN THEY SAY YOUR CHARGE PORT IS BAD OR BROKEN, IT MAY JUST NEED CLEANING.
THERE IS A STUFF YOU CAN BUY ON EBAY MADE BY A COMPANY CALLED "CRC". ITS CALLED "CO CONTACT CLEANER" ESPECIALLY MADE TO CLEAN ELECTRONICS. YOU SPRAY IT ON AND IT EVAPORATES STRAIGHT AWAY AND DISSOLVES ALL DIRT,HAIRS AND FIBRES THAT BUILD UP WHEN YOU PLUG YOUR CHARGER IN ALL THE TIME.
THE REASON I`M TELLING YOU THIS IS, FOR THE PAST WEEK OR SO I`VE BEEN HAVING THE SAME PROBLEMS YOU`VE BEEN EXPERIENCING...SO I GOOGLED IT AND FOUND OUT MY PORT MAY BE DIRTY (UNDERSTANDABLY) SO I SPRAYED SOME OF MY CONTACT CLEANER INTO IT AND STRAIGHT AWAY MY GALAXY 2 STARTED CHARGING PROPERLY AND STOPPED RAPIDLY LOSING BATTERY POWER AS IT HAD BEEN DOING.
HERE IS A LINK WHERE YOU CAN BUY THE CLEANER FOR $12.10 WHICH IS ABOUT HALF THE PRICE YOU`LL FIND ON EBAY ( http://hardware.gotstock.com.au/ppc/crc%... )
CRC, CO CONTACT CLEANER. DATA SHEET
Features
Plastic safe formula which is technically proven, stable, inert high purity cleaning solvent
Non corrosive, non staining, rapid complete evaporation; contains no lubricants
Does not contain CFC 113 or methyl chloroform
Flammable formulation
Removes contaminants from precision electrical/electronic equipment
Applications
Suitable for relays, switches, circuit breakers, alarm and signal systems, printed circuit boards, connectors and generators, contacts, laboratory and test equipment, video heads, drums, terminal plugs and jacks (deactivate equipment before use)
SORRY FOR THE LONG ANSWER, BUT I THINK IT WILL SAVE A LOT OF PEOPLE A LOT OF HEART ACHE.
I`M NO EXPERT,BUT IT WORKED FOR ME !!!
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
3
Отмена
Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите «Прикрепить комментарий к этому сообщению», чтобы переместить его.
