The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
359 Questions Показать все
cycle lights blink washer will not run
washer will not run . no codes, cycle light will blink once when start is pushed
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 0
Добавить комментарий
Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
Посмотрите наш магазин
5 Ответов
Выбранное решение
Unplug it for 5 minutes to allow it to reset then plug it back in and see if it gives you any codes.
Был ли этот ответ полезен?
по рейтингу 1
the door lock light didn't come on. when I unplugged the electric and plugged it back in the door light came on. it ran thru a couple minutes then shut off when the door light went out. can you help me? thank you.
fred
по рейтингу 0
when i put a load in it starts and then stops and the light start blinking and i have to move the cloths around in the drum - or take some cloths out - but that only works sometimes.
по рейтингу 0
Washer stopped with twelve minutes left on the timer clothes are dry enough to take out.the washer will not restart. I unpluged the machine for five minutes and when plugged back in no code appeared. When it was plugged back in a real low hum could be heard but still will not do anything
по рейтингу 0
After turning power on I push the start button and hear a humming noise. Please help
по рейтингу 0
Добавьте свой ответ
michealwing будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 8
За всё время: 1,311
