iPhone 5 can't restore - Stuck at "Waiting for iPhone"
I have an iPhone 5 that's really giving me a headache.
At first it started up but the screen wouldn't come on = it synched with iTunes and vibrate on/off worked, but replacing the screen didn't work. There's no visible liquid damage but I suspect it might have been a victim of a static discharge working environment.
I've had the backlight coil replaced(the likely suspect) on the logic board but now it's stuck in DFU-mode and won't go any further than "Waiting for iPhone" in iTunes and an Apple logo on the screen with an empty progress bar below. Now I'm thinking the backlight coil might not have been faulty after all.
What are the likely suspects in this case? I'm tried to restore with several dock connectors/flex cables and USB cables but nothing seems to work.
Could it be the flash memory? Any good ideas for a fix that doesn't require completely replacing the flash chip?
Это хороший вопрос?
I have the same issue!!!
из Marcos Antonio Elgueta Soulat
I have the same issue too!!! :)
из tcepertintodo
I have the same problem on iphone 6 plus.. let us know if you find anything please
из Masoud Rahshani
i have the same problem on Ipod 2
i found this solution, i will try it, so i wanted to share it with you :
( To do this, hold down the On/Off button until the iPod shuts off. Then hold down both the Home and On/Off button for 10 seconds. Let go of the On/Off button but keep holding the Home button for another 10 seconds. iTunes will tell you that you're in recovery mode and that you must restore your iPod )
из falconstyle
i have the same problem too, with iphone 6, my phone displays apple logo and recovery mode only while its kept on charging through the electric chargers
while its connected to pc, my phone does not support, its totally black,
after pressing the sleep / wake and the power key, itunes detect the phone in recovery mode, but while restoring the itunes get stucked in waiting for iphone screen
please help me
из pvnvarma
Показать 6 больше комментариев
