Шестое поколение iPhone компании Apple, представленное 12 сентября 2012 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в Черном или Белом цвете.
2522вопросов Показать все
iPhone 5 can't restore - Stuck at "Waiting for iPhone"
I have an iPhone 5 that's really giving me a headache.
At first it started up but the screen wouldn't come on = it synched with iTunes and vibrate on/off worked, but replacing the screen didn't work. There's no visible liquid damage but I suspect it might have been a victim of a static discharge working environment.
I've had the backlight coil replaced(the likely suspect) on the logic board but now it's stuck in DFU-mode and won't go any further than "Waiting for iPhone" in iTunes and an Apple logo on the screen with an empty progress bar below. Now I'm thinking the backlight coil might not have been faulty after all.
What are the likely suspects in this case? I'm tried to restore with several dock connectors/flex cables and USB cables but nothing seems to work.
Could it be the flash memory? Any good ideas for a fix that doesn't require completely replacing the flash chip?
Это хороший вопрос?
Оценка 30
11 Комментариев
I have the same issue!!!
из
I have the same issue too!!! :)
из
I have the same problem on iphone 6 plus.. let us know if you find anything please
из
i have the same problem on Ipod 2
i found this solution, i will try it, so i wanted to share it with you :
( To do this, hold down the On/Off button until the iPod shuts off. Then hold down both the Home and On/Off button for 10 seconds. Let go of the On/Off button but keep holding the Home button for another 10 seconds. iTunes will tell you that you're in recovery mode and that you must restore your iPod )
из
i have the same problem too, with iphone 6, my phone displays apple logo and recovery mode only while its kept on charging through the electric chargers
while its connected to pc, my phone does not support, its totally black,
after pressing the sleep / wake and the power key, itunes detect the phone in recovery mode, but while restoring the itunes get stucked in waiting for iphone screen
please help me
из
Показать 6 больше комментариев
Добавить комментарий
17 Ответов
Наиболее полезный ответ
Solved
Hi Guys, I had this problem with my iPhone 5s.
iTunes was "waiting for iPhone", Phone was working perfectly before I decided to update via iTunes and the problem was the phone would not restart after software extraction.
Anyway the problem seemed to be my USB 3 hub which I should point out works perfectly with all other apple products but for some reason iTunes didn't like it while updating or restoring my iPhone 5s.
So I plugged the cable directly into the PC' s USB 2 port and it worked fine!
Hope this helps someone...
Был ли этот ответ полезен?
Оценка 22
12 Комментариев:
Wait usb port 2 where is that
из
This worked for me too. Thanks!
из
Thank you! This helped me a lot!
из
While I didn't expect that to work, it started to update as soon as I moved the cable off of the USB hub. Thanks
из
absolutely worked. thanks.
из
Показать 7 больше комментариев
it is hardware problem,nand capicitor is failed
Оценка 6
3 Комментариев:
Behzad, which one?
из
how to fix this problem
из
it seems so, my iphone was dropped in water. what's its solution. How to and which chip need to replace?
из
1- I change the USB cable
2- I removed the front Camera
It works after 2 weeks of trying many things with many software and it was showing everytime the same result : stuck with the apple Icone with the loading circle (Waiting for the phone ) in itunes.
BTW My power button doesn't work
Оценка 2
2 Комментариев:
hey thanks mate, it works
из
Hey, what i need to do/
из
@joebrownyh. Thanks a lot! It worked for me by connecting it through " iPhone Data Recovery" tool. Just launch the application connect you iPhone. Just remember to close iTunes before launching the recovery app.
Оценка 1
1 Комментарий:
This worked for me to exit recovery mode to normal mode but still waiting for device even on "iphone data recovery tool" for iphone 6, will try changing the cable also
из
I just had this issue and went to a convenience store to buy another USB cable and it fixed it, now I am restoring from backup.
Оценка 0
As long as nothing is actually wrong with your iPhone, you can exit Device Firmware Update (DFU) mode without restoring the device in iTunes. To get out of DFU mode follow the same steps as a forced restart.
1. Hold down the Sleep button and Home button at the same time.
2. After a few seconds the Apple logo appears and the iPhone will boot.
3. Your iPhone is now out of DFU mode.
If the procedure doesn't work the first time, try steps 1-2 again. If something is wrong with your iPhone you may need to restore your iPhone 5 using iTunes.
Оценка 0
I hope this guide helps you.
How can I restore iPhone 5c without iTunes backup
Оценка 0
Just making sure you are running iTunes 11.1....?
Try a DFU mode. Disclaimer: This is seriously at your own risk as its the most basic level a phone can boot into and thus opens it up to a much more severe bricking sequence. It's like recovery mode but plug into computer, hold the home key + power button for 10 seconds, release power button whilst still holding the home key for an additional 10 second then release. iTunes should say its detected a phone in recovery and the device's screen will still be black. You need to get the timing of 10 seconds as close as possible. If you achieve this then go through attempting a restore of iPhone stuck in recovery mode.
It's radical but it's a shot. Otherwise you can just call tech support line at 800-MY-Apple/visit retail store and work through it to a hopeful resolution. This is sadly, but honestly, the risk you take with buying a brand new device on it's first day or launch.
Оценка 0
its a driver prblm
Оценка 0
3 Комментариев:
How do you fix
из
I saw your comment on youtube also how do you fix it
из
Sorry for the two previous comments that was me using the wrong account
из
If you can‘t update or restore your iPhone, iPad, or iPod touch
You can put your iOS device in recovery mode and then restore it with iTunes.
In these situations, you might need to use recovery mode to restore your device:
iTunes doesn't recognize your device or says it's in recovery mode.
You see the Apple logo on your screen for several minutes with no progress bar.
You see the Connect to iTunes screen.
Learn what to do if you see the progress bar on your screen for several minutes.
Put your device in recovery mode and set it up again
1. Connect your device to your computer and open iTunes. If you don't have a computer, borrow one from a friend or go to an Apple Retail Store or Apple Authorized Service Provider for help.
2. While your device is connected, force restart it: Press and hold both the Sleep/Wake and Home button for at least 10 seconds, and don't release when you see the Apple logo. Keep holding until you see the recovery mode screen.
3. When you see the option to Restore or Update, choose Update. iTunes will try to reinstall iOS without erasing your data. Wait while iTunes downloads the software for your device.
If the download takes more than 15 minutes and your device exits recovery mode, you'll need to repeat these steps and choose Restore instead of Update when you get back to this step.
4. After the Update or Restore completes, set up your device. If you previously backed up your device with iTunes or iCloud and had to restore your device in step 3, you might be able to restore from your backup during setup.
You can also follow this step by step tutorial for your problem:
Whatsapp Recovery
How to restore whatsapp messages from itunes backup
How to recover whatsapp photos from iphone
Оценка 0
1 Комментарий:
When it says, waiting for iphone, it fails. It won't pick up the iphone. The iphone is dead and won't turn on to Apple logo to put it recovery mode to get the option to restore or update. While it is off, I managed to put it in DFU mode then it says restore and update, I can't choose between, i have to click that, after I click restore and update, it attempts to restore and fails when it reaches waiting for iphone section
из
My issue was solved by switching to original Apple charging cable.
Оценка 0
I faced to the same problem with my iPhone 6
This is the solution ,
First Install the latest version of itunes to your PC
After the installation restart yor PC
Then Turn off your device (Iphone Ipad etc..)
Open iTunes in your PC
Connect the USB cable to your device and connect to PC
Now turn on your device,
Next you have to put your device to recovery mode .. to put that press and hold Sleep/awake button and Home button together for 10 second then you will see that your device is restarting but don't get your fingers out from the buttons.. after appearing apple logo you will see a message connect itunes,
Now open iTunes and after few seconds a message will appear that saying restore or update ,
Press restore and update ...
After downloading the file itunes will restore files to your device..
Now if the problems "Waiting for iPhone"
or these errors,
The iPhone [device name] could not be restored. An unknown error occurred (9).
The iPhone [device name] could not be restored. An unknown error occurred (4005).
The iPhone [device name] could not be restored. An unknown error occurred (4013).
The iPhone [device name] could not be restored. An unknown error occurred (4014).
Try to change your USB cable to original or a better one , or
Try to restart your pc and follow above steps, or
Try to install with another PC...
This methods should work fine ...
Оценка 0
Apple seems to have an issue in the update software. It is causing a lot of iphones to over heat. The issue is not phone specific it is happening with all iphones from 5 to 6 and 6 plus I have heard of so far.
Оценка 0
guess my problem was the battery connector not connected internally. I watched a youtube video, saw this possibility, opened my cel and bamm, connected the battery connector. Cel phone started normally. thanks
Оценка 0
It may be a hardware issue. Many people are still facing this same problem.
Оценка 0
iPubsoft iPad iPhone iPod Data Recovery is a powerful yet all-in-one data recovery tool which enables you to recover deleted SMS and Contacts from iPhone easily and quickly. With it, you can also get back all your lost iPhone data and files, such as photos & videos, contacts, SMS, call logs, memos, calendars, Safari bookmarks and more no matter they lost due to device loss, jailbreak, iOS upgrade or factory settings restore.
How to recover the data from iphone ?
Оценка -1
No matter you have created backups of your iPhone or not, here in this guide you will get ways to retrieve the deleted data from iPhone 6/5C/5S/5/4S/4 with the help of an iPhone data recovery tool.
Оценка -2
Добавьте свой ответ
Anders будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 10
За последние 30 дней: 53
За всё время: 202,738
