GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
151вопросов Показать все
Logical board and 3G gsm modem surface-mounted ribbon cables
Dear Everybody and Ifixit!
Please help me!
I have an ipad 2 gsm. I had to change the screen and digitizer. In some reasons i hurt the surface mounted ribbon cable between the modem and the logical board. Right now i can't make a restore, because the itunes can't install the firmware to the modem.
Please help me fix it! If this is not possible have any possibility to skip the modem? I don't care the 3g if the ipad will be work!
Thank you very much!
Regards
Janaboy
Some pics:
Это хороший вопрос?
Оценка 0
4 Комментариев:
How do you solve the problem?
из
Laspik78, to solve this issue you should simply solder back the damaged flat cable.
It is not a difficult job for someone with the right tools, skills, and experience.
On the other hand, it can be pretty messy and hard if the above prerequisites are not met.
If you want to send it out, choose someone with a proven track record otherwise things can go wrong and you end up with a brick.
If you should need help choosing someone, let me know, I could be able to recommend someone depending on your location (country, state).
из
Just use double sided conductive tape after cleaning off the old be very careful not to damage the tabs press down hard and maybe clamp itbfor a bit, no need to solder it that's a cowboy way
из
The ipads that have 3g have an extra section attached to the logic board by a glued on wire. I bought this at a tag sale. Someone was apparently trying to repair their iPad and they did not know that when you removed that glued strip attaching the 3g antenna to the logic board you would never be able to re-atach it again later. So basicaly my 3g logic board is now in two pieces. the main logic board with wifi and the cdma 3g antenna. Now their is no differnce between the logic boards in either wifi only or wifi and 3g devices. I attempted to restore the device with the ios for wifi only, because there are 3 different ios versions depending on if you have wifi only wifi 3g with SIM card, or wifi 3g cdma.
из
Добавить комментарий
2 Ответов
You may be out of luck. You can try to manually download the WIFI only version of the software, but I don't think that will even work.
I think the best recommendation I can give is that you get a new logic board/modem and swap it with your broken one. Or you can try to get someone to solder the modem back in place.
You may be able to find a company online who does this type of solder repair, but the price may be close to the cost of buying a whole new logic board.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
I had the same problem...but now its solved
из
i tried double side conductive(z axis) but no use
i tried soldering.....again no use and it is also very very very difficult
i found a link from gsmhosting.com.......i bypassed the gsm module......
finally my iPad2 is working but ...... i cannot use gsm anymore.
http://forum.gsmhosting.com/vbb/f631/byp...
из
Thanks guys for helping!
After many months i have a friend who have very high skills in soldering and he created a new ribbon cable..now its working perfectly..
Оценка 0
Добавьте свой ответ
Janaboy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,255
