How do I replace the charger conection on the phone?
The charger connection on the phone has gone bad and won't charge. Is this something that can be replace?
Это хороший вопрос?
Это хороший вопрос?
It will have to be soldered on. I do this everyday but if you are a novice this may a little to difficult. It requires special soldering skills to do. You can easily overheat the circuit board or pull a solder pad up. I would look for a good local cellphone repair shop. Should be about 60 dollars to replace. Good luck.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 206
