Repair guides and support for the laptop line of Acer's Aspire series for casual home and business use.
895 Questions Показать все
Repairing Disk Errors is looping
Hi, I turned my Acer Aspire v3-571G laptop on and it started saying 'Repairing disk errors might take up to an hour'. Then the screen goes black after a while, then a blue screen with a sad face pops up saying something about an error then it starts all over again.
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 0
Добавить комментарий
PC Laptop Batteries
An easy fix for a big power boost.
Купить сейчас
PC Laptop Batteries
Купить сейчас
2 Ответов
Выбранное решение
Your hard drive may be in the midst of failing.
To verify this you have to look at the drive with another operating system and run a diagnostic test, especially looking for the S.M.A.R.T. data stored on the drive. Two ways to do this:
One, Boot your laptop from a bootable diagnostic CD such as HIREN or The Ultimate Boot CD. Once booted, each has several HDD diag utilities.
Two, and my preferred approach, is to remove the drive from the laptop and attach it to another machine where you can run Windows-based diags, such as HD Tune.
Most important here...do you have a backup of your data?
Был ли этот ответ полезен?
по рейтингу 1
Комментарии:
I have a nitro Acer 5 and I'm not getting errors it's just been loading for 19 hours I went to bed after factor resetting my laptop but the repairing disk errors came up and I went to bed after hearing it might take a while if anyone can help me understand what to do,pls because I want to start playing rainbow again
от
Let It Finish Overnight
First of all, “Repairing disk errors” is triggered by automatic CHKDSK on booting. As we all know, CHKDSK indeed plays a good role in scanning and repairing disk problems. Plus, most of time, CHKDSK may take a pretty long time to finish, such as 4 hours or more. So, it’s advisable to leave your computer running overnight to let it finish. But, the next day when you wake up and check PC, if “Repairing disk errors” issue persists, you can move on to try the other means.
https://www.errorsolutions.tech/error/wi...
Solution 3. Replace the HDD and Install Windows
по рейтингу 0
Добавьте свой ответ
Simeone будет вечно благодарен.
Просмотр статистики:
За 24 часа: 1
За 7 дней: 16
За 30 дней: 58
За всё время: 3,784
