Won't turn on or be recognized by anything.
Hello
I have a smartphone/tablet reparing company in Denmark. I have repaired a lot of iphones, but sometimes very unfortunate things happen.
I had a customer today, who needed a screen replacement, as the screen was cracked. My partner replaced the damaged screen assembly and out everything in place, no problem there. When he wanted to turn it on to test it, nothing happened. He tried connecting it to a wall charger, nothing. PC couldn't recognize it also. He tried to change back the screen to the original one, nothing again. He then tried a new battery and also new dock connector, still no reaction. It won't even go into DFU mode.
I took a looks at it and saw this potential damage that has occurred, i believe when he was going to take out the Dock connector flex from the logic board.
http://img607.imageshack.us/img607/2355/...
Is this causing the failure to start it? If so, what can be done, jumpers etc?
Это хороший вопрос?
Bilal Kinali, any chance that you can post another image and mark the part that you are looking at? Right now, I see the shield but not anything suspicious...;-)
из oldturkey03
Point out the part that you see as damaged....
из oldturkey03
me too! that happend
из jahred
Sorry about that. Here: http://imageshack.us/photo/photo/819/yc5...
I already tried another working 4s logic board inside this phone and it works perfectly, so it is only the logic board that is damaged.
из Bilal Kinali
Slet lige dit "svar", du har skrevet som et svar på spørgsmålet.
из Bilal Kinali
Показать 3 больше комментариев
