Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Шестое поколение iPhone компании Apple, представленное 12 сентября 2012 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в Черном или Белом цвете.
3418вопросов Показать все
iPhone 5 screen is loose
My screen protrudes too much from the rear case assembly because the rubber/plastic (?) material which originally lined it on the left side has separated, and as such it is free to move around in that area.
I am wondering which options exist for replacing or repairing this issue, preferably without buying a whole new display assembly. Do I just need to apply adhesive to the side of the glass? Better yet, can I buy a new glass and swap it for the one of the assembly I have right now?
Это хороший вопрос?
Оценка 1
Добавить комментарий
3 Ответов
Выбранное решение
If it is not affecting your phone other than moving around a bit, I would just leave it. Replacing just the glass is near to impossible since it is heated onto the LCD. You could try buying a case that secures the phone together, that way you wont be letting dust and dirt in there.
Был ли этот ответ полезен?
Оценка 1
I would recommend to either get a case that would not allow it to move. Like Dustin said you cannot just buy the glass and replace it that way. It requires very expensive equipment to do that. I would also look up your serial on Apple's website and see if it's under warranty. If it is, then schedule a Genuis Bar appointment at the nearest Apple store to see if they would swap out the part or phone for you.
https://selfsolve.apple.com/agreementWar...
Оценка 1
If the phone is within a year you can take it back to apple for an exchange. I'm sure they will give you a refurb but its better than what you are doing now.
Оценка 0
Добавьте свой ответ
Marcus McLean будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 22,779
