First generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
124вопросов Показать все
Вопрос закрыт
Ipad screen is half black but the screen stills detects touchh
the screen is half black holding it from bottom to top and this happened after i dropped it,but the screen looks fine on the surface, and when you unlock it from sleep mode it looks sort of cracky from the inside corner where i dropped it...is it the screen or software? do i need to replace something? thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
visible screen and touchscreen are 2 different screens
so your touch is working ok but lcd screen is broken and needs replacement
there might be loose ribbon cable somewhere but most likely you have to get new screen
Был ли этот ответ полезен?
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 2,480
