The Nokia Lumia 920, developed by Nokia and released in November 2012, utilizes Windows Phone 8 operating system.
69 Questions Показать все
USB Connector Cable torn down
Hey guys,
I have made a disply replacement on my Lumia 920. Thanks for the tutorial. It works!
Unfortunately I torn down the USB Cable at the begin of the disassembly. I bought a new one. The same problem with the new one. In the moment when I am closing the case the cable is squeezed and then its torn down.
Is it possible to make a soldering or to use any glue?
Best regards
David
Это хороший вопрос?
по рейтингу 0
Добавить комментарий
iPhone X Fix Kits
Warranty up? No worries, we’ve got the fix.
Купить сейчас
iPhone X Fix Kits
Купить сейчас
1 Ответ
Hi,
You can not use soldering option here unless you are willing to risk your device for soldering however you have to buy a new usb cable and connect it if you think you can not achieve that percision then take it to a local repair shop for fitting the case after plugging usb cable. Try to keep a steady hand while fitting if you give it a retry.
Good luck.
Был ли этот ответ полезен?
по рейтингу 0
Комментарии:
Hi,
thanks for your quick reply. OK I will try it a third time with a new usb cable. Hope not to squeeze the connector.
от
Добавьте свой ответ
David Obladen будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 359
