An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
89 Questions Показать все
Why will my Gameboy Advanced SP will not charge or turn on?
I got a GBA SP from my friends and I tried turning it on but it would not turn on. I then plugged it in to the charger. It flashed orange really quickly and then would stop charging. (Note: My OTHER friend said that the battery swells up on those things and it looks like that might be the case but I don't know how to fix that either.) If someone could help me figure that out I would be pretty happy!
Это хороший вопрос?
по рейтингу 7
Комментарии:
Same thing for me, but the battery replacement didn't work
от
I've diagnosed the problem with mine, the wiring between the charging port and the battery is somehow broken.
от
Same problem
от
Do a bridge on the F2 fuse.
от
Добавить комментарий
PC Laptop Batteries
An easy fix for a big power boost.
Купить сейчас
PC Laptop Batteries
Купить сейчас
4 Ответов
Tommy the very first thing you want to do is to change your battery. Here is the guide for it. The battery is available at places like this. Hope this helps, good luck.
Был ли этот ответ полезен?
по рейтингу 0
Комментарии:
Already did. No help
от
I think you should bye a new gameBoy Advanced SP
по рейтингу 0
по рейтингу 0
All you need is a new battery :)
по рейтингу 0
Добавьте свой ответ
Tommy будет вечно благодарен.
Просмотр статистики:
За 24 часа: 1
За 7 дней: 7
За 30 дней: 36
За всё время: 11,662
