The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
463вопросов Показать все
Backlight doesn't work after LCD replacement.
I had a cracked LCD screen. Prior to disconnecting the LCD cables the backlight worked fine. I replaced the screen but since then the backlight doesn't work. I confirmed the backlight cable and LVDS cable are securely attached. What are the possible causes?
Это хороший вопрос?
Оценка -1
1 Комментарий
Did u get this fixed ??
из
Добавить комментарий
2 Ответов
Выбранное решение
Blown fuse/controller for the backlight. This is not a DIY repair unless you work with electronic component replacement on a regular basis. Logic board soldering requires special tools, solder & lots and lots of practice.
Follow the tag at right for more information.
If this answer is acceptable please remember to return and mark it.
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
Is there a way to confirm this visually before taking it in?
из
Kimberly, if you have a multimeter you could check the fuse for continuity.
из
Where is the fuse?? Location
из
Check your backlight cable ... I installed mine the way the cable was positioned and best I got was black screen with faint apple symbol .....
But turns out I had it in backwards ... Was very awkward to flip cable and install bit that was it , try that just for !@#$% and giggles
Оценка 1
Добавьте свой ответ
Kimberly будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 381
