CPU Fan runs at full speed.
Hi, the CPU fan of my iMac is running at full speed. iStat says it's not running (0rpm). The temperatur sensor is working, my ASP says, that's a problem with the logicboard. Any resets (SMC, PRAM) are done but this problem is still there. I just bought an external fan control but first I want to ask if somebody know the pin assignment of the CPU fan plug.
Это хороший вопрос?
4 Комментариев
Has the hard drive ever been replaced?
из mayer
Nope only the fan has been replaced.
из [deleted]
Many thanks
I found this page while looking for answers to the fan running fast problem.
The resistors can be found in the UK on eBay if you do a search surface mount resistor 47k ohm
Got mine here
https://www.ebay.co.uk/itm/100-X-RESISTO...
You get a hundred of them but you will need a few as they at so small you lose them .
из Paddy Apple
@gunar0585 como resolveu? meu imac ano de 2010 só fica com a ventoinha em rotação máxima
из georgeeditor
