An affordable Windows phone by Nokia, released April 2013.
82вопросов Показать все
screen is out of calibration maybe?
i cracked my phone and just replaced my screen but now when i touck the screen it moves around like the screen is out of calibration but u cant calibrate the lumia 520 but also the screen works fine after i turn it off then back on and i can use it only if its on a flat surface and if i pick it up it messes up again
PS. i have already tried the factory reset it dont work
Это хороший вопрос?
Оценка -1
2 Комментариев:
"i can use it only if its on a flat surface and if i pick it up it messes up again" double check your connectors as well as the ribbon cable.
из
im having the same issue but i want to know if there is any way i can fix this asap
из
Добавить комментарий
2 Ответов
Sounds like maybe a clip that holds the digitizer ribbon secure might not be done up right, and it only makes the right contact when its sitting down on a flat surface
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Also looking back at your old post it appears that you got it water damaged it could be related to that, check to see if you and see any white powder looking substance on the board and clean off gently with a toothbrush and rubbing alcohol if you find any.
из
I have a couple of these devices doing the same thing. I did a glass replacement and the touch will work for a minute but once you press down slightly on the glass it makes the digitizer go crazy. I have it happening to three different devices right now. They were working fine until I needed to use the part for another device.
Оценка 0
Добавьте свой ответ
Benjamin Walls будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 10,861
