Пятое поколение iPhone. Ремонт данного устройства простой и требует только отвёртки, лопатки для открытия и терпение. GSM/CDMA / 16, 32 или 64 Гб / Черный или Белый.
2993 Questions Показать все
black screen after screen replacement won't power?
Hi, I just have replaced my iphone 4s screen but, my iphone won't boot anymore. 5.1.1 is installed on this phone.
All plugs/harnasses are connected correctly.
Any ideas? If I try to update to 6.1.1 my Itunes says error 3194.
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 0
Добавить комментарий
Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
Посмотрите наш магазин
4 Ответов
Выбранное решение
Sorted I have 5.0.1 Ios and original screen sorted the problem thanks all.
Был ли этот ответ полезен?
по рейтингу 0
You should double check your connectors, also clean them, if you are still having problems you should try another screen.
по рейтингу 0
Комментарии:
Thanks I am on my second screen and nothing has helped yet. Going to try a third screen many thanks.
от
It sounds like you may have damaged the battery connector to the motherboard. Try pushing down on the battery connector and powering it on. you may need to plug it in while doing this. If it turns on this is your issue. if not check the 6 contacts to the motherboard around the battery connection to make sure it hasn't been damaged. Let me know if this helps
по рейтингу 0
didnt help yet. I have inspected it no damages.
It powers up in DFU mode but, not in normal mode.
no screen black screen flickers. Some people told me ios 5 is causing the issue.
по рейтингу 0
Комментарии:
iPhone won't power on after repair..
Maybe I have this issue..........
от
Добавьте свой ответ
Tarou будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 168
