iMac wont boot up, just the apple screen shows. Can anyone help?
My iMac turns on and has the apple screen on with the boot up continually running. There is a little circle thing that indicates that it is trying to boot up. But nothing is happening. CAN ANYONE HELP ME???
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
much worse is relative - it's always bad when something like that happens
but i would do pretty much the same
- reset the iMac like this and that
if the iMac still won't boot
- use the instllerdisk and try to boot up. use the disk utility to check/repair permissions
a few more infos are here
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
great answer if the asker knows that those colored words are links to solutions. Also how to start up from the installer disk.
из
you're right richard - i didn't think about that. but here we go: you have to press and hold the C key your keyboard to start from the installer disk
из
Добавьте свой ответ
melisag247 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,760
