The phone was dropped into water, will it ever work again?
the phone was dropped in water - will it ever work again?
Это хороший вопрос?
Это хороший вопрос?
Try!
Open it clean the PCB with alcohol and preheat it with a hairdryer. Check everywhere for water. Assemble it after 24 hours.
If you are lucky... :)
Regards.
Был ли этот ответ полезен?
thanks very much guys - will have a go
The same happened to me 4 years ago. It automatically shut off itself immediately. At home I cleaned and dried it, First 2 days it was like dead, then started again and is functioning nicely until today ( except the missing app supply, but that's not a fault of that nice phone)
Dropped a Samsung Galaxy in a sink of water.
Amazingly, the 'phone still worked afterwards ... but it wouldn't charge. Took the back off, removed the Sim card, unscrewed and took off the cover of the charge connector. Then put it on a hot radiator for a day.
It now works a treat.
Key is ... not to drop it in water (obviously!), but if you do, get it out as fast as possible (it's surprisingly well sealed so water doesn't get in that fast), open up as much as reasonable, wipe off any visible water and try to evaporate off the rest.
If your Nokia Lumia phone has been dropped into the water,a good tip is to cover it with rice for at least one day.The rice will absorb the remaining water and the phone will function again.I had that problem and this tip worked.
Hi,
This link may be of interest to you. You may not be that lucky a second time when trying to use rice and wet electronics
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 861
3 Комментариев
Don't forget to change the battery after you cleaned your phone properly
из oldturkey03
My phone has a Crack and yhe screen doesn't work for some reason
из daritza
My nokia lumia 800 is completely broken water also has got in i need to how i can fix it problrms are
+Screen is completely broken
+battery tray is popping out
+it is not powering on nor charging
Hope u have a fix for this problems
из OldVMe Rayaan
