Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418вопросов Показать все
MacBook appears to have power, but doesn't boot...
Bought a used MacBook, with the description that it "just stopped working", just to see if it was fixable. Unit appears to get power, when the power button is pressed, the light on the front near the IR sensor comes on doesn't blink. Hard drive sounds like it has power as well. Screen stays blank, but does flash as if it were to start coming up but stays black. I figure I'll try to connect it to an external display as soon as I can get an adapter for it. I do not get a chime sound when trying to power this up.
The LED on the mag adapter is currently orange and the battery LED's blink on the level of charging status. Light on the mag adapter will go to green if connected and the battery is removed.
So far I've tried switching RAM, resetting the PRAM, and resetting the SMC. I have taken the unit apart to inspect, the mother/logic board doesn't appear to have any damage to it, unable to see any blown transistors or anything like that and otherwise appears in good condition.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Try starting from the installation disk, "C" key and see what problems persist to eliminate any system and/or hard drive issues.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
I should also mention again that the unit doesn't chime (not sure if sound on board is messed up or not). I'll probably be getting the mini-dvi adapter tomorrow to see if I can get anything to display.
RAM has been tested in another laptop with Memtest86 for the last 24 hours, and no errors have surfaced so the RAM appears to be good. Will begin testing the hard drive tonight.
из
Добавьте свой ответ
Josh Douglas будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 1,032
