Компания Apple представила iPhone 5s 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в цветах: Серебристый, Золотой и «Серый космос».
3531вопросов Показать все
Why dose screen seem to have white lines appearing in back ground
My screen seems to have faint white lines running top to bottom in the back ground of my screen. On occasion the screen will go black an than come back on its own. When it comes back it still seems to have the white lines? Does anyone know what might be causing this? Thanks for any help.
Это хороший вопрос?
Оценка 32
6 Комментариев
Thanks for the replies is it possible that a small fall could dislodge this connection? This is my Daughters phone who works at a Vet. She said when she bent down to pic up a dog her phone fell out of her pocket. so it didn't fall to far and worked fine after that. This problem started about two weeks latter while she was sitting down using her phone.
из
I had two customers with iPhone 5 S same this problem. First one, touch screen was working with white lines and second one , touch screen was not working. Just it needed to replace touch screen chip and I did that and the white lines gone and touch screen start working.
из
my phone fell now i have the white lines at the top and it is really frustrating as the screen no longer responds when i touch it on a regular basis and occasionally works when the back of the phone is hit on my leg but then shorty stops working
из
I dropped my iphone 7s in a pool filled with dry ice. It won't turn on anymore. Please help!!
из
I have an android, never dropped it or banged it on anything. I did download a game and played it for two months they had a few updates after that the lines started on my phone. I did erase the game and all content of it. Same problem, an ideas?
из
Показать 1 больше комментариев
Добавить комментарий
34 Ответов
Наиболее полезный ответ
Был ли этот ответ полезен?
Оценка 5
6 Комментариев:
That happens to me to I don't now why if I didn't drop my phone and the white lines are there I tried to turn it of or make your phone die but I couldn't.
из
when you say touch screen chip do y ou mean the touch screen or the chip on the logic board?
из
what chip?????????
из
Touch screen IC on logic board
из
how much is it
из
I dropped mine in water but last night the lines weren't there, when I woke up this morning they appeared and they won't go away. I can still touch my phone and everything works right except the lines. They blink in and out sometimes, I've reset my phone, taken the screen off and put it in rice but, the lines won't go away, do I need to go get my screen replaced or what exactly do I need to do?
Оценка 4
2 Комментариев:
Hey did you ever figure out this issue? I dropped the top half (from earpiece to maybe half way down) of my iPhone 6s into coffee and I immediately dried it and it was fine that day. But today I have faint blur lines, sometimes dense blue lines and then beyond that sometimes a clear screen. Did I damage the lcd or an internal component?
из
What u did now to this phone
из
How can i get a black line out my phone
Оценка 2
2 Комментариев:
Might just need to repair it
из
you need to replace the screen, happened to my old phone
из
I went to a cave and I put my phone into a waterproof bag and carried with me.. after some water activities I saw my phone was wet and I quickly grabbed my Samsung galaxy j7 prime from the waterproof bag. I wiped it and started to off it because I was scared if any further problems will happen. Then after that, i back sensor was not really sensitive and I tried so many still cannot... Then when I brought to the shop he said the humidity in the air might turn into water vapour and got into my phone screen.. while I and the shop people were talking my phone screen suddenly turned to white grey vertical line.. Can anyone please help me...
Оценка 2
Your screen is not seated securely on the logic board, did you have your screen replaced recently? If not then take your iPhone back to Apple for a replacement.
Оценка 1
4 Комментариев:
railmanm,
из
But would it cost some money?
из
mine literally just isn't working and im not sure why.. The lines appeared completely out of the blue, but it hasnt been dropped at all recently or in any water damage
из
Horizontal line appears on my phone travel down and disappear. No fall,nothing and only I updated software...Worried, what could be the reason
из
You could try a hard reset or a full restore if it just happened out of the blue..
If it was dropped then it's lcd damage..
But if just happened for no reason then I would get it replaced under warrenty ..
Оценка 0
2 Комментариев:
Had this happen one on a iPhone 5 I was repairing I just unclipped the connectors reseeded and worked 100%
из
Con how do you do that that's awesome if you see this. Comment plz answer it I need help and I'll be taking
из
It could be a screen that went bad. But I just purchased a replacement screen and upon installation the screen was black with white lines. I had just about given up but tried one more time to put it on and it worked. I think the LCD connection is very sensitive and if it's not perfect it will display those lines. Just an observation based on personal expirence.
Оценка 0
I replaced a cracked scrren in my phone (5) not s, and the new ones has very, very faint vertical on it, almost hard to see. Just wondering if there is anything I should check, or something I may be able to reseat or tweak to get rid of them???
Оценка 0
I left my phone on all night and I got black lines on my scree what do I do ??
Оценка 0
I don't know what to do
Оценка 0
There is a line on the screen of my phone what can I do to fix.
Оценка 0
2 Комментариев:
Yh I need help to
из
Smash it get new one
из
Why are vertical whir lines go down my screen
Оценка 0
It's either the LCD going out or it got wet. Had mine in my pocket while walking during a heavy down pour within a hour the white vertical lines appeared.
Оценка 0
It might have water damage my old phone did it I took it to the phone shop and they said it's got water in the battery there's nothing u can do about it apart from get a new phon
Оценка 0
1 Комментарий:
If your phone got wet, take the back off and put it in a big ziplock back with uncooked rice, leave it over night. Should help. Good luck
из
I dropped my Iphone 6 multiple times but nothing broke. Then a week later white lines start appearing and won`t go. My friend said its a virus but I don`t know. I tried restarting it 2 or more times, its doesn`t work
HELP!! ESAP
Оценка 0
1 Комментарий:
My brand new phone got white lines around the screen and I haven't dropped it yet or put it on water
из
I want to stop the lines on my phone
Оценка 0
When it was raining ☔️ I thought it was in my plastic bag and I dropped it and it was still working at first and then it cut off and then It had a bunch of red and white lines and it still works I'm charging it now
Оценка 0
This is likely to screen connection issue. You need to tear down the phone and properly connect the screen. On an iphone 5, at the top right corner, there should be a metal shield. If you have a toolkit, remove that and firmly press all of the connections. That is my solution.
Оценка 0
My phone
Fill in a water and i pulled rice and my phone got line
Оценка 0
1 Комментарий:
me too in alcohol
из
This is happening to me too it honestly helped when i shut my phone comepletlty off and let it sit over night.
Оценка 0
I honestly turned my phone off and let it sit.
Оценка 0
Hi yeah you needn’t to replace the screen and put the thing in together as it may be wonky or you could go to woolich phone shop and he pulls fix it for you
Оценка 0
Put it in rice fo 24 hours it should be back to normal if that doesnt work take it to ur phone store.
Оценка 0
I did a re-set. Solved the problem on my iphone
Оценка 0
1 Комментарий:
IPhone reset fixed it
из
I have an Android phone, the white lines happened, but I had the phone for 4 years I pushed the amount of gig's alotted for this phone. The bottom line was the screen was going out. Got a new phone, all better. Support always ask if you dropped it or banged it against something, I never did. Sorry If I didn't help.
Оценка 0
I have an iPhone and a reset fixed this problem with the state lines
Оценка 0
It happens when digitizer connector is not connected on the motherboard or is faulty. You must disconnect and connect that again to solve this problem.
Оценка 0
Hello…this is what I'm seeing on my J6 phone screen. What could've caused this and what should I do?
Оценка 0
Was screen ever replaced, or OEM screen?
Оценка 0
Mine is too I neeed help
Оценка 0
What can I do when my Android phone have white lines on it?
Оценка 0
please help me how to move them
Оценка 0
1 Комментарий:
It probably is a backlight issue, you would have to order a new backlight or screen, or have a reputable repair store do it for you.
из
Hiiiii! Same thing happened to me, I dropped my phone, white lines appeared! I left my phone alone without touching it and a lot of them disappeared! I don’t know if they’ll come back, but for now im grateful it was white lines and not colored lines.
Оценка 0
i dont know i have this problem too :(
Оценка 0
2 Комментариев:
when i use alcohol in my phone the white line appeared help me plss :(((((
из
water damage :(
из
Добавьте свой ответ
railmanm будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 10
За последние 30 дней: 36
За всё время: 213,569
