other pepole can`t hear me
i have a problem with microfone, i can`t hear nobody, i already change the dock with microfone complete new and this option don`t help me. I need change something else? where?
Это хороший вопрос?
Это хороший вопрос?
If people can hear you it's not the audio ic chip
I would try another chat hour port it's possible you bought a faulty part.
Try this when you get new part see pic
Actually install it directly without taking the charging port out then insert battery and start up phone the make a call and see if that mic works
It saves you time from taking phone apart if part doesn't work..
I do this with most repairs it saves time if parts faulty
Был ли этот ответ полезен?
If you can't hear them either and they can't hear you there is a problem with you audio ic chip.. Try this
i try this think and dont help me,
this is what i do for try fixit:
1 change complete connector dock with new mic
2 follow your advies
the strange is i change all things and still the same, i mean i ear the people btu they can t ear me, if i talk hands free they ear me fine or by viver skype etc, what i need to do more?
Definitely start with with Con's link. Also, new dock connectors typically have bad mic's. For whatever reason they have really high failure rates. You should check the return policy.
I go try that again like you say, with new part, because I have done at begin, change all dock part inc mic, so I go buy a new item I will try again once thanks I let you know what happens then
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 131
