My galaxy 3 tablet keeps getting hot what do I do?
Its getting hot, I mean very hot after only a few minutes of use. And its only in one corner. Its the left upper corner.
ΠΡΠΎ Ρ ΠΎΡΠΎΡΠΈΠΉ Π²ΠΎΠΏΡΠΎΡ?
Upper Left corner is where the battery starts its charge... or discharge... I'm guessing that theres a short in the battery. I'd send it in to get looked at
ΠΡΠ» Π»ΠΈ ΡΡΠΎΡ ΠΎΡΠ²Π΅Ρ ΠΏΠΎΠ»Π΅Π·Π΅Π½?
But its not getting hot while its charging. It could just be sitting there and I pick it up and its reallly hott. Cause I thought about it being something with the battery so I checked while it was charging and it was cool as a cucumber. Thats why im so confused as to whats going on.
Well, then your battery doesn't idle when you lock it, it's still discharging when you're not using it. Are you experiencing less battery life? If so it's most definitely the battery... Get it replaced!
As far as I can tell the battery is fine. Ill watch it closer the next few days though. Thank you.
No problemo!
actually samsung galaxy tab gets hot really quick due to usage of RAM and cpu so its normal . it is not mad for heavy use just to store pics listen to music and to play a small game and when u do something which takes alot of RAM and cpu the tabs left side will get ,infact the cpu is on the left.
Thank you!! Ive noticed its only when im using netflix or playing a game so that makes sense!! Big weight off my shoulders!! Cuz I cant afford to fix it if something goes wrong!! Thank you!!
That make since if I leave an app running then pick up my tab its hot as on the left corner
It keeps getting hot my tablet
u must had kept it on a tv or laptop or a computer thats why or else water must have entered in it or battery problem
what do I need to do if it gets hot only on the top left side and it shuts down and does not turn on again even if it has been regarged
My tablet gets hot all on the left side top and bottom whats wrong
Only curtain games make it hot
That happened too my tablet 3 galaxy it gets hot at the top of the corner it will frieze the screen will stop that happened to my know I have a tablet 4 it gets hot at corner
I think when your continually using the tablet for gaming or installing stuff it does get hot just let it cool down and try not to use it to much
My tab is get hot what to do
I have a galaxy tab three and same thing happens I don't I know what to do I got it when it came out as a freebie from wireless company when I was getting a new phone I took the offer and not it's getting hot and we have other tablets and we never had issues with those thinking of taking it back to be looked at
In my opinion put yor tablet on charging in that room which is cool don't keep it near the room which is very close to kitchen as it could be heated by steam from kitchen!
Actually its cuz of the way u use it. If u leave it in charge and use it, it will get hot. U have to be careful. Use it for about an hour and let it cool. If it still gets really hot, don't use it and power it off
I play words and scrabble and my tab 3 gets real hot in 2 hours or so. I turn it off for a few minutes and it cools down to normal
galaxy j3 suddenly got as i was on phone, not hooked to charger. why?
Chances are the battery is getting warm. Try replacing it.
ΠΠ° ΠΏΠΎΡΠ»Π΅Π΄Π½ΠΈΠ΅ 24ΡΠ°ΡΠΎΠ²: 2
ΠΠ° ΠΏΠΎΡΠ»Π΅Π΄Π½ΠΈΠ΅ 7 Π΄Π½Π΅ΠΉ: 6
ΠΠ° ΠΏΠΎΡΠ»Π΅Π΄Π½ΠΈΠ΅ 30 Π΄Π½Π΅ΠΉ: 23
ΠΠ° Π²ΡΡ Π²ΡΠ΅ΠΌΡ: 35,093
3 ΠΠΎΠΌΠΌΠ΅Π½ΡΠ°ΡΠΈΠ΅Π²
i had a rca tablet and the battery on it quit working and it wont even charge anymore
ΠΈΠ· Michael Wilson
My rablet gets hot regardless of amount of usage, or type of usage. I've even unplugged the chargeing cord, and the tablet still continues to heat up. I turn the hot area in another direction and the opposite area then gets hot as well. I'm exteremly baffled.
ΠΈΠ· Suzanne Johnson
Suzanne. So, if your tablet gets hot when it's charging, that's normal. When it's charging, the battery is getting power but also releasing it at the same time, so the battery will heat up because theres twice as much going on in there. If it gets hot whether it's charging or not, that's most likely the CPU. If it is, then when you use an app that uses a lot of recources (Like a 3D Game) it will get hotter, but it shouldn't overheat.
ΠΈΠ· Mount MC
