The GE Profile Tri-Temp is a free-standing water dispenser with an integrated chilled compartment.
46вопросов Показать все
The power is on but the water won't dispense
Hi, my water dispenser always worked fine until recently. I stopped using it for about 2 years so it was sitting and not being used, though it was plugged in and powered on the whole time. I recently decided to start using it again, but I can't get the water to come out. It did for a day or two after I started using it again but stopped for some reason. I did notice that the reservoir seemed to have an ice "ring" around the inside of it...basically like a block of ice shaped like a donut. I don't know if that's related.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
I'd unplug it and let it come to room temperature for a couple of days. This should reset it and allow it to defrost (if that is ice). Plug it back in and let us know your results.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Matt будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 13
За всё время: 947
