Internal battery not powering unit
The camera works fine when connected to a backpack battery or is being powered thru USB. But when it's just the battery installed in the camera, it receives no power - regardless of which battery is installed.
Any ideas?
Это хороший вопрос?
Ian, does this "regardless of which battery is installed." mean you tried a new battery? Have you checked the make sure the contacts are properly lined up?
из oldturkey03
Yes. I tried swapping the battery in the GoPro with the one in the backpack (the backpack, when installed, powers the unit) and it did not power up. The three battery contacts in the camera do not seem to be corroded or misaligned in any way. They line up fine with the slots in the battery.
из Ian
