Выпущен в июне 2009 г. / Процессор Core 2 Duo 2,66, 2,8 или 3,06 ГГц
Pink lines suddenly appearing on display
My macbook's main display has mostly horizontal pink lines that flash within certain fields on the screen that are otherwise normally white (browser windows, text fields, etc.)
It happened spontaneously and without warning a week ago. The display was fine one minute, then suddenly the pink appeared.
My external display that runs out from the laptop is unaffected. Also, applying pressure to the underside of the laptop (pressing in between where the two fans are) stops the issue on the main display.
Would love suggestions on how to fix it? My laptop is a 2009, but I'd like to get a few more years out of it.
Only recent changes to it where the installation of mavericks about 6 months ago and a ram upgrade made at that same time.
Это хороший вопрос?
Счет 4
Добавить комментарий
7 Ответов
Выбранное решение
Pressing on the case does not make sense here given the fact you state the external monitor is AOK. Assuming the external monitor image is good all of the time I would focus on the internal monitor signal pathway from the GPU to the LCD its self.
Often I replace the complete lid assembly when I get these types of issues as the driver logic on the back of the LCD unit or the LDVS cable has become damaged. While it is possible to disassemble the lid to get to the LCD and/or the LDVS cable you do end up damaging a few parts in the process and can also break the cover glass if you are not careful.
Did you bang or drop your system as some point or did it get wet or sit in a puddle of liquid? You may just need to clean the logic board and/or LDVS connector & cable end on the logic board. Follow this IFIXIT guide MacBook Pro 15" Unibody Mid 2009 Logic Board Replacement from the start to step 6, then jump to step 20 and stop there.
Make sure you have an ESD mat & wrist strap and the proper tools. To clean the logic board (or any spots that need cleaning). Use a can of Can'ed air a soft painters brush to wipe the dust off, and use distilled water (not tap!) with some cotton swabs (Q-Tips) and lastly, some good quality Isopropyl alcohol 85% or better. Wipe the surfaces with the a slightly damp swab with water first (if needed a few times) then go over them again with the Isopropyl alcohol. The alcohol acts as a drier here pulling the water from underneath. In any case make sure things are fully dried before powering up.
Был ли этот ответ полезен?
Счет 3
9 Комментариев:
Thanks for responding, Dan. No, I've never dropped the computer and I don't believe I've gotten it wet. The laptop also doesn't do a lot of traveling, mostly has just sat on my desk. Pressing on the case may not make sense, but it works: applying pressure to the points in between the two fans does cause the screen to function. I have it sitting on top of a rolled up wad of duct tape at the moment and that is enough to keep the primary display pink-free, for now.
I should also mention that earlier, my trackpad went completely haywire -- but the problem ceased. Could it be a static/electric issue?
Thanks for the cleaning instructions. I'll give them a shot and report back.
из Поделиться
Looks similar to this problem:
Pink lines in white space, green lines in black space?
I also guess it has something to do with soldering issue on the logic board.
из Поделиться
Hue - Good catch! Yes, it's the same issue! In both cases the LVDS cable/connector at the logic board appear to be failing.
из Поделиться
I have this exact problem with my MacBook!! Has anyone managed to definitively solve it? If so, I'd love to hear what you did...
из Поделиться
Yes! @marsguit - Bad display, LVDS cable or the GPU.
Now you'll need to figure out which by using the diagnostic process I outlined above.
Does an external monitor look OK if so it's not the GPU. Then you have either the display or the LVDS cable. Since its a big job to replace the cable its just easier to replace the display assembly which comes with a new cable.
из Поделиться
Показать ещё 4 комментариев
Наиболее полезный ответ
None of these solutions worked for me unfortunately. So for others still struggling with it, what did work for me was re-calibrating the display colours:
1. System preferences
2. Display
3. Calibrate
4. Continue
5. Un-check "use target white point"
6. Move the bar until the lines disappear.
Hope this helps!
Счет 15
10 Комментариев:
I don't think thats the root issue here. While one can alter the color bias using the calibrate assistant a Pink hue display is not normal. Within MacOS High Sierra you can now alter to color temp to be easier on your eyes. Basically it's moving from 6500K daylight to 3000K warm incandescent lamps. Here's a bit more on color temp: Color temperature.
The issue here is like this: Pink lines in white space, green lines in black space? not an overall color shift. If you shifted the color temp all of the other colors would end up being off and white wouldn't be white.
из Поделиться
@Dan
I totally agree. I'm not tech savvy, and also don't have the time nor the funds to try my luck with Apple to fix it. Mostly for me was about looking for a quick fix. And i'm happy with the result, I don't mind the white in my screen not being so white. But I understand if the point of this is not a quick fix. If you find my comment truly unhelpful then by all means delete it, or if you want I can. Thanks!
из Поделиться
I figured you didn't see this as it was a bit hidden under the 'show 2 more comments'
No, this is still not a workable solution. The system just can't calibrate this as its just to extreme a bias.
из Поделиться
Thanks Mills, your solution worked for me (y)
из Поделиться
Thanks Mills. Has worked for me. My screen is now less glaringly bright white which is probably better for my eyes.
из Поделиться
Показать ещё 5 комментариев
There was a simple solution in my case. The screen looked pink at certain times of day - hint, hint. Go to System Preferences > Display > Night Shift, and if it’s on, turn it off. I had turned it on with good intentions, but the color shift from sundown to sunrise seems far more drastic on a laptop screen than it does on an iPhone. I hope this solves your problem, too.
Счет 1
  1. you have a problem with GMUX chip. Perhaps it is LVDS connector. To sure diagnose press lightly with your finger on LVDS connector, when image become clear, it is the LVDS cable.. and you must clean it with alcohol and fine brush.
  2. when you press lightly the GMUX chip and lines dissapear, then you must exchange this chip. This IC has a solder joints problem, that after years fall connection between chip and Logicboard, so it must be reball, or exchange and programmed(from old one) with new one..
Счет 1
2 Комментариев:
Regards,
Mac-Retter
Hamburg, Germany
из Поделиться
I had this problem with a MBP 17" 2010. As Ser Gre suggests the issue is from the GMUX chip (U9600 on the MBP 17" 2010). Some solder balls under the chip makes bad connection with the board. The chip needs a reflow or a replacement.
из Поделиться
I might be a little late on this, but hey, a fix is a fix I guess.
I recently had the same problem on a 2009 MBP.
Turns out this can be solved by re-calibrating the screen.
Click on the apple logo -> System Preferences -> Displays -> "Color" tab -> Calibrate -> continue until you reach the "target white point" option -> slide to left or right depending on if you prefer warmer/colder color -> starting from a specific point the pink will disappear, continue and use the newly created profile.
It is not the prettiest solution as the white on your screen will not be completely white anymore, but if you don't mind having a slightly more yellow or blue white it works perfectly fine. For the 2009 MBP this seems to have completely solved the problem.
Just posting this in the hope it will help someone + sorry for bumping an old topic.
Счет 0
2 Комментариев:
@mathimat - I don't think thats the root issue here. While one can alter the color bias using the calibrate assistant a Pink hue display is not normal. Within MacOS High Sierra you can now alter to color temp to be easier on your eyes. Basically it's moving from 6500K daylight to 3000K warm incandescent lamps. Here's a bit more on color temp: Color temperature.
из Поделиться
It's not the root issue but you try getting a second hand working motherboard for an outdated powerbook!
из Поделиться
There was a simple cure when this suddenly appeared on my MacBook. System Preferences > Display > Night Shift. Turn it off. I had turned it on with good intentions, but the Night Shift effect is far more drastic than it seems on an iPhone.
Счет 0
I had this issue while updating the system version.
The story goes like this.
I need to update my system. The machine has been bugging me to update for weeks.
I remove external monitor and power
move laptop to other room. Closer to WiFi.
I start up ate. It seems to proceed OK.
About twenty mins later the screen is black
I restart the laptop.
I get the pink lines
restart again. I get the system updating loading screen
twenty mins pass. I see this string about the pink lines. I think is have a video issue. I’m planning a trip to the &&^&^$^ apple store
I move laptop back to the other room plug in external monitor and power
Loading screen appears on external monitor with some time left on the up load
The upload completes
i get normal working screens on my laptop and external monitor !!!
im not sure what happened. Perhaps I caught the updating in mid update so it showed the pink lines. Not sure.
Счет 0
Добавьте свой ответ
Dan буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 88
За все время: 74,871
