A Windows phone known for its camera capabilities. Also known as Nokia EOS, Nokia 909, Nokia RM-875, Nokia RM-877, Nokia RM-876.
42вопросов Показать все
Can the side buttons flex cable be replaced on a Nokia Lumia 1020?
Can be replaced side buttons flex ? i saw the video from Le55on from Nokia Lumia 1020 but is not clear for me if the side button flex can be replaced?
Mine sleep button failed so i need replace the flex from side....
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
If the phone is still under warranty, send it back for a replacement.
If this helps, please click on Accept Answer, thanks!
Update
The 1020 was released in July '13. There should be a 1yr manufacturers warranty, regardless of the carriers insurance. Use this website to determine your warranty under Nokia
http://www.nokia.com/us-en/support/warra...
Let us know if this helps.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
sure is not on warranty coz otherwise i would send it
из
I have the exact problem. The power/lock button is physically ok but it's stuck pressed. I know this because when i only hold the volume down button pressed the phone soft resets. Can some one please provide a tutorial how to replace this flex cable.
Alex or anybody, if you found a solution for this please let me know here or on my email cevi_stefan@hotmail.com Thanks.
из
Добавьте свой ответ
Alex будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,042
