Пятое поколение iPhone. Ремонт данного устройства простой и требует только отвёрток, лопатки для открытия и терпения. GSM/CDMA / 16, 32 или 64 Гб / Черный или Белый.
2193вопросов Показать все
The volume buttons won't work one my iPhone 4s
when i click the volume buttons, the screen just says ringer, the sound doesn't work for spotify, youtube, and it's doesn't ding for texts or notifications, but if i set up an alarm, or go into setting and mess with the sounds and alerts bar, the sound works. i don't know what's going on and i need help!
Это хороший вопрос?
Оценка -1
Добавить комментарий
4 Ответов
Наиболее полезный ответ
Be sure your phone has been currently updated
Is your phone in silent mode? Check the side of the phone where the vibrate/silent button is located. Also be sure to go over your settings as well to ensure everything is set up correctly
Был ли этот ответ полезен?
Оценка 1
I have had this problem before usually means the iPhone is in docking mode and would need a replacement dock connector.
Before replacing this part try cleaning the port with an unused tooth brush and some pure alcohol.
Hope this helps :)
Оценка 1
I'm having the same problem thinks its got to do with the new iOS on iPhone 4s
Оценка 0
I normally isn't a problem with the IOS. Clean out the charging dock with a clean toothbrush, there should be no need to use rubbing alcohol. That is what worked for me.
Good luck!!
Оценка 0
Добавьте свой ответ
jade будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 7,213
