The GE Profile Tri-Temp is a free-standing water dispenser with an integrated chilled compartment.
Why is my cold water not cold?
My water cooler was working and all of a sudden the water is not cold. What do i do?
Это хороший вопрос?
Счет 11
12 Комментариев
yes the unit is getting power
из
yes the cold water lite is on but not the hot water lite
из
So you get hot water but not cold - correct?
из
Having same problem. Any answers?
из
When i turn hot water switch on my cold gets warm near to hot why? If i new how to set temperature i would do that. Because my whole jug gets warm. Could be that im out of freon or low?
из
Показать ещё 7 комментариев
Добавить комментарий
2 Ответов
Выбранное решение
Check the plug & outlet and the fuse/breaker. Is the unit getting power?
If the unit is getting power then the compressor is not working correctly. It could be out of Freon or the compressor its self is shot. Which is why you aren't getting cold water.
If you are getting cold water not hot then the heater unit is burnt. In some units the waste heat from the compressor is used which can explain why you're not getting either hot or cold.
Был ли этот ответ полезен?
Счет 13
10 Комментариев:
Yes mine has hot water but the compressor not on very hot it is now unpluged
из
And my cold water is hot I chrck fuse is ok and the breaker has power light on the on/off switch
из
Please let me know where and how to get to the FUSE! Please
из
Review this series of YouTubes: Troubleshooting a GE water dispenser and installing a GE heater element (part1). It will give you an idea on how your stand-alone unit works. Sadly, GE doesn't offer parts for this unit as they classify it as non-repairable.
из
The hot water is working fine but the cold water is not cold and compressor is switching on and off by itself and I just bought it newly and I don’t know what to do. Kindly assist
из
Показать ещё 5 комментариев
If you can hear the compressor running and it does not shut off, then the unit is low on Freon.
Счет 3
6 Комментариев:
how to fix fereon
из
freon is a liquid inside the compressor used for cooling I think. But I'm not someone who has expertise in this type of repair.
из
If motor feels hot disconnect the plug
из
Where is the fuse??
из
How do I add Freon to a unit
из
Показать ещё 1 комментарий
Добавьте свой ответ
felix quinones буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 10
За последние 30 дней: 84
За всё время: 93,496
