Samsung Wave II S8530 (или «Samsung Wave II») — это преемник смартфона Samsung Wave S8500, работающий под управлением операционной системы bada 1.2 от Samsung, который был выпущен в продажу в октябре 2010 года.
How can I do a master reset without previous owners pin code?
Hi. I got a samsung wave s8530 from ebay and it wont let me master reset without previous owners pin code. It is running Bada 1.2 and I tried a few tricks like volume button holding with home button etc to get to a menu screen but no luck, think some techniques work just for androind OS ?
Can anyone help??? Thanks
Это хороший вопрос?
Счет 3
Добавить комментарий
3 Ответов
Выбранное решение
Hi in the end i tried all the various pin coses without success. But finally managed it by plugging into computer and using the samsung kies program. Thanks
Был ли этот ответ полезен?
Счет 1
Наиболее полезный ответ
If you can't get an answer from the previous owner, file a complaint with eBay and send it back and leave negative feedback for this seller.
Счет 3
justin, try this. Remove your SIM and Memory Card, then dial *2767*3855# (here are two other codes that you can try if the first one does not work *7465625*638*00000000*00000000# and #7465625*638*00000000#) and wait till the phone reboots. If that does not work, you most likely will have to flash your firmware. For that, check on here. Hope this helps, good luck.
Счет 2
2 Комментариев:
I have similar problem with my s8500. Everythink was exellent. But why to not set up password...? I did it. Whats happen next? I forgot it. Phone was wait for new battery and I forgot password.
After restart, phone asking me for password. Its 8 digits max. No accept #. That your suggestion is wrong. Its not full keyboard accesible. Only 8 signs.
из
Same problem with my Wave 525 S5250
из
Добавьте свой ответ
justin буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 24
За последние 30 дней: 40
За всё время: 8,812
