External storage options by Seagate, usually connected by USB, available in many storage sizes and form factors.
46вопросов Показать все
Can't access data on 1 TB Seagate Pocket External Hard Drive?
Cant access my Data on this External hard Drive, I can on android tablet but not on any windows system did try on win 8.1 and win 7, did it from a Desktop , Laptop , work workstation on win 7 etc.. worked on my Android Tablet with no issue, also does work on a WD Multi-Media device, just FYI, am assuming it may be related to a Corrupted Deep Freeze Software which I have installed on my System which did Cause my win 8.1 do halt the Shut-Down PC system on my win 8.1 which I have get it rebuilt, I did all from Check disk you name from Computer manager etc... if you right mouse click oin the Drive you will see Zero data on it, however if you go to computer manager and you access it from there you will see the normal used and empty data on this drive, so I cant figure out and on how to access this DATA,
so IF any Clue , Pls Let me Know , would be Awesome to find a Resolution to this,
by the way, when you do try to access the data on this Drive via window , an exception come up with Access denied, cant locate.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Did you tried detecting your external hard drive with a data recovery software? I suggest you scan your hard drive with any of the below recommended data recovery utilities for Windows.
1) http://www.stellarinfo.com/windows-data-...
2) http://www.remosoftware.com/data-recover...
If the software scans your hard drive & shows you all files that you are unable to access right now then you can recover them. Scanning for inaccessible files on a hard drive is free on both the above mentioned software. Hope this works.
Был ли этот ответ полезен?
Оценка 1
To recover accidentally or permanently deleted data from external hard drives, you can use Windows Data Recovery Software. In the internet market there are lots of professional software available such as: SysInfoTools, Kernel, Aryson, etc that easily recovers all hard drives lost data. By using the recommended software, you can get back your accidentally deleted data such as:- files, folder, image, video and more other items.
Оценка 0
Добавьте свой ответ
Walter будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 3,591
