Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154вопросов Показать все
Post battery Swap, display Rotation Issues, Thoughts?
I just swapped out the Battery on my iPad 3rd Gen, Since then, i am not able to rotate my display, the functionality is great, but the system will not rotate the display. I am at a loss, and worried i might have shorted something out, or that there will not be any repair possible.
Has anyone run into this, or does anyone have something I can Try?
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Make sure you haven't the rotate locked.
Also try a restore to rule out software fault..
If above doesn't work then it's a motherboard fault
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
skyeahrens будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 72
