Screen popping out of cover
Screen keeps popping out of aluminium casing when opening the top. After closing you can push it back together again.
Machine works perfectly.
Это хороший вопрос?
Это хороший вопрос?
HI Peter,
Is your MacBook Pro new? Did you change the protective glass?
Well it looks like your bezel is coming out most likely because the adhesive does not hold anymore!
My advice remove the protective screen, using the Pro Tech tool kit, get some proper adhesive and fix it back...
I have just replied on another post about changing just the screen, go and see it you might get a more accurate answer ;)
If you like my answer, just don't forget to score it...
Thanks,
Max
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 501
