Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Acer Aspire V3 Series Laptop. Sometimes referred to as Q5WV8.
12вопросов Показать все
Is there a problem with my battery?
My laptop does not last more than 30 minutes on a full charge. What should I do?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
2 Ответов
Наиболее полезный ответ
Make sure the outlet your cable is plugged into works properly by using another electronic device. Make sure your cable is fully plugged into the outlet. If the battery still has minimal charge capacity consider buying a new one and replacing it with this guide.
Был ли этот ответ полезен?
Оценка 1
I think you battery is damaged and first thing you need to do please change your battery because a damaged battery can harm laptop as well. According to me for laptop support service you need to take help from experts.
Оценка 0
Добавьте свой ответ
Lance будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 202
