Вопрос закрыт
Machine yanks up ~ 100 degrees Celsius when eg. Safari is active
Hi there! I worked on this 15" late 07 MBP. Removed the MB, took out all the dust, removed the dry thermal paste & added fresh one. Cleared cashes, ran DW, DiskUtility and AppleJack -> everything is fine! But yet, u open eg, Safari (nearly idle), MacsFan Control, says the CPU temp is nearly 100 degrees C and both fans are running at 6500 rpm. Did I go wrong somewhere?
The battery is zilched out, u can use powercord only.
Any suggestions what else to do? Thanks for help
Alex the Kraut
Это хороший вопрос?
Оценка 0
1 Комментарий:
Probably this model: Apple MacBook Pro "Core 2 Duo" 2.4 15" (SR) Specs
Identifiers: Mid/Late 2007, 2.4/2.2GHz* - MA896LL - MacBookPro3,1 - A1226 - 2136
из
Добавить комментарий
1 ответ
First reset the SMC: http://support.apple.com/kb/ht3964
See if it will start without the battery and see if the problem persists.
Do a Force Quit to see if any programs are running in the background.
Был ли этот ответ полезен?
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 82
