An Asus netbook laptop, released Feb of 2010. The device model number is specifically 1005PEB-RRED01S. This netbook is fairly difficult and annoying to take apart because it uses an awkward tab system to hold onto some of the components.
Why won't my battery charge?
I plug in the power adapter the wall and to the computer to charge the battery. The battery charge light on the laptop does not light up and Windows does not recognize that it is plugged in. If I unplug the laptop from the wall, it will turn off.
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
This is typically an easy and cheap fix, but is entirely hardware based. Potential issues range from a broken outlet or power adapter to a broken battery. For help on identifying the issue, and replacing the battery if necessary, visit this guide.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Blake Motl будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 1
За последние 30 дней: 10
За всё время: 1,074
