Шестое поколение iPhone компании Apple, представленное 12 сентября 2012 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в Черном или Белом цвете.
3313 Questions Показать все
Black screen & beeps after battery replacement
Hi everyone!
I've searched around the web and i can't seem to find an answer.
The other day i replaced my iPhone's battery, and ever since the screen wouldn't turn on and when plugged in it would just beep every few seconds or so, no apple logo, nothing. Just a black screen, with no power.
When plugged in, vibrates as if it were turning on, and then the beeping begins.
I thought something might be disconnected but i checked the screen connectors and the battery connector and everything seems fine.
Any ideas?
Thanks everyone.
Отвечено! View the answer У меня та же проблема
Это хороший вопрос?
по рейтингу 3
Добавить комментарий
Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
Посмотрите наш магазин
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
4 Ответов
Выбранное решение
Repeated bonging noise is a damaged display seen it many many times you might have damaged the cables without even knowing .. A new display will fix this
Был ли этот ответ полезен?
по рейтингу 3
Same happended to me, let me tell you why it happened first, you did not unpluged the screen in your phone, you replace the battery without removing the screen. EVERYONE IF YOU GONNA REPLACE THE BATTERY PLEASE REMOVE YOUR SCREEN. I replaced the screen as suggested and now the phone is working perfectly.
по рейтингу 0
I have the same problem too. Beeping without apple logo, blank screen.
So did u solve the problem ? When I replace the battery I do remove the Screen.
It is need to replace a new screen will do ? Any website can buy the screen ?
по рейтингу 0
I solved it.
Replacing the battery WITHOUT disconnecting the screen connectors busted the screen. So i inevitably had to replace the screen as well.
по рейтингу 0
Добавьте свой ответ
Miguel Alonso будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 7
За всё время: 4,013
