Repair guides for smartphones manufactured by LG that use the Android operating system (OS).
2553вопросов Показать все
Вопрос закрыт
Why doesn't LG Optimus G Pro screen turn on after I repaired it?
I just finished repairing my lense screen and after I assembled it my screen doesn't turn on? What can I do? Is it fixable?
Это хороший вопрос?
Оценка 0
1 Комментарий:
Did you double check your work? Did you make sure everything is properly connected? Have you tried the old screen to make sure you have a working phone? Why did you replace the screen? what happened to your phone before?
из
Добавить комментарий
1 ответ
Carefully inspect the LCD flex that connects to the board, or in this case I believe it connects to the charge port flex. Try applying a little pressure to it or check for any signs of laceration, if the flex is torn at all then the LCD is no longer good. I make the comment about the pressure because something similar happened with an LG G2 i fixed. No image on the LCD but when I would play with the flex the image would show.
Был ли этот ответ полезен?
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 422
