schematic of logic board
Where can i find a schematic of the logic board. i want to know what chips do what so i can fix them more efficiently.
Это хороший вопрос?
Это хороший вопрос?
afaik - there are no schematics around.
but some repair guides can be found if you google hard enough
the answer to your problem is in the other question
Был ли этот ответ полезен?
Depending on the terms of the NDA, you may be able to get schematics from someone who signs up with Apple Dev Connection as an iOS device accessory manufacturer (Made for iOS, MFi). If it is a legacy product that is not currently sold or officially supported, I wish that the schematics would be made publicly available.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 6,098
Which model are you referring to?
из rab777hp
most iPod parts are not only soldered to the logic board - the are "glued" to it. so replacint is not easy. i had a few bottles of a acid mixture to remove them - worked great - but it was extremely aggressive, never got this stuff again (it was from china, but a friend bought it with other parts in istanbul)
из markus weiher
I have been working on the iPod touch 1st gen 8gb and 16gb so far. like right now i have a 8gb that works on everything except whatever makes the backlight work on the lcd. i tried multiple lcd screens and same problem on all of them. even tried them on a different lcd and worked great so its something in the logic board
из chad franklin
