Guides and support for various television (TV) brands and styles.
9094вопросов Показать все
Sony Bravia KDF50E-2010 50" LCD HD TV won't power on?
Hello,
I have a Sony Bravia KDF50E-2010 50" LCD HD TV. The red light flashes three times.
What shall I do or what part should I purchase to fix on me own Sony Bravia 50" tv?
When I try to turn it on first green light flashes about 25-30 time. Then I get one red light and the other red is flashing 3 time (continuesly).
Is it worth and possible to fix?
I will be really grateful for your help!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Martin Hawrylo,
If your television is not turning on or showing any signs of life, see the Insignia NS-24ER310NA17 Will Not Turn On problem page for possible causes and solutions.
This error can be caused by a bad bulb, or a bulb that is not tightly secured as well as the the lamp door isn't tight. Check on those things first. Hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Martin Hawrylo будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 462
