water damaged iPod touch
I recently washed out my iPod. It will power on but nothing else. What can I do?
Это хороший вопрос?
Это хороший вопрос?
My iPhone is water Damaged how can I fix it?
If you accept this answer please remember to come back and mark it.
Good Luck
N.
Был ли этот ответ полезен?
leave it in the sun for a few days ,turn it off straight away,never try to plug it in the computer this will only fry it.try leaving it a box of rice in the sun(the rice will absorb moisture). pull the ipod apart into pieces to see if any water is actually in your ipod
good luck
grab a cotton bud and dip it in nali polish remover insert the cotton bud with nail polish remover into the headphone jack hopefully this will help
Never use anything like acteone or similar to clean anything it may do more harm then good. If you got to clean it, use isopropyl alcohol....
It sounds like it went through the washing machine, that translates into soapy water, which conducts electricity even more ...a bad thing. It also likely did more damage than say ...just falling into the toilet for one second [common!]. The damage has been done by backwards routing of battery voltage and breaking conduction between internal layers/connectors [soap].
Solution? Christmas is fast approaching... Apple techs can also detect water damage, so warranty coverage may be out, but if you are a pretty girl or know a pretty girl, she/you may be able to sweet talk a nerdy electronics counter person into a swap. That's my best advice other than sending to Apple for repair.
I have dried many similar devices with 97% isopropyl. At the pharmacy you will find two grades, and obviously 97% has way less water than the 70% and will work best for displacing hidden moisture. The problem with your device was the inability immediately remove the battery soonest upon dunkage [water]. More importantly using alcohol to dry electronics is for advanced Technicians only, please read.
[CRITICAL] The liquid isopropyl is highly flammable and the vapor is explosive. Use with adequate ventilation which is not a nearby electrical fan. You MUST be sure to not have the battery [or any source of spark!] installed when using highly flammable 97% isopropyl on any electronic device. Read other warnings on the isopropyl package and read the Material Safety Data Sheet here
Besides burning without a visible flame (am I on fire?) or exploding (Gramma is that you ..but I thought you were dea...?) concentrated alcohol can remove the oils from your skin, resulting in a minimum, painful hangnails [wear nitrile gloves?]. So your DIY necessity should truly be a Risk Assessment. Is it worth it? Feeling confident? Safety first! Music on your iPod is like 28th, according to Maslow's hierarchy of needs
Absolultey not! She would be better off using IPA, more honest!
Take it apart and put the parts in Isopropyl Alcohol(99%), this will remove ALL corrosion
Put everything in besides the screen assembly and digitizer, these are fine after 9 out of 10 times and may crack during disassembly(digitizer, not screen)
Nick a beginner will not know what you mean by IPA. Please simplify your answers.
I would just refer to established guides that will help with the cleaning as well as the disassembly i.e. iPod Touch 3rd Generation and Electronics Water Damage It is less confusing and that way everybody is on the same page for any follow up questions.
IPA = Iso-Propyl-Alcohol
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 7,294
