Won't turn on, but makes a beeping sound.
My Xbox 360 S wont turn on, but it makes a beep when I touch the power button and eject button. The power supply light is a solid Orange, and the USB ports look good. (nothing touching metal-saw this was a issue on youtube). I've done everything that Microsoft said to do, like unplug everything, change outlets and still nothing.
This is what happened:
I turned it on, everything was fine. there was a update, so I did the update. It loaded fine. i was at my home screen and the wife wanted to watch a movie so I went to "my video/movie". it just kept on loading and wouldnt load. So I turned the xbox off, and went to turn it back on and it wouldn't work.
HELP PLEASE. My warranty expired 5 months ago...my luck!
Это хороший вопрос?
22 Комментариев
I have this problem too but I spent about $200 on it for downloaded games
из michael odaniel
I have had the same problem. buying a new ROL/rf module on eBay and it worked two times i was excited and then it stopped working. so i know it does have to do something with that piece but there must be a short somewhere. i can't see anything else that would make it short out. none of the USB prongs are messed up. I've checked everything that youtube and the internet have suggested. The part i bought was used for about 5 dollars. they have one new that i saw for around 15 but it ships from china and takes up to a month to arrive. not sure if its worth spending another 15 dollars when i could put that towards a new machine.
из joe
i have this same issue i dont know what to do in order to fix it
из Haley Cassell
I had the same problem take out the hard drive and blow inside to get out some dust. Then place it back in, works like a charm for me. If it doesn't work for you then go into the settings and uninstall that update.
из Asad Alli
I have this same issue like word for word except I believe the power brick is red.
What I don't understand is I took my son's power brick which works on his elite Xbox and I get same result when hitting power button.
I do not have a hard drive only onboard 4GB storage.
из Jamie Lawson
Показать 17 больше комментариев
